following some iratic idleing i cleaned the throttle body and the ICV with carb cleaner.
i wish that i hadnt bothered touching the icv now as it seems to of made the problem worse.
upon starting the car the idle is fine and is steady while stationary a few blips it seems to be ok and falls back to 1000 rpm no worries.
when you put some load on the engine and drive off the idle speed will then stick at 2000 some times 3000 rpms.
ive had the icv off a couple of times and re cleaned, with no cure for the problem so im getting close to the purchase of a new one now.
couple of things, does the icv need to be lubricated maybe before refitting ? would a bit of clean oil in there do any harm (like a dribble applied with a cotton bud or something, not pouring it in!)
lastly the actual icv is rivited to a plastic L piece which bolts to the inlet manifold, in my previous car the icv was bolted direct to the throttle body and looked like this :
http://cgi.ebay.co.uk/Idle-air-cont...226886QQcmdZViewItem?IMSfp=TL0808051119a33079
do renault supply a new one complete with this plastic fitting or will it come like the above e bay one, there for requireing some fiddling and whatever to make the new one fit.
thanks
Graeme.
thanks
Graeme.
