Idle problems 2007 Clio 1.2 16v
  renault clio
Hi, I'm just wondering if any of you guys could diagnose a problem I've started to have recently with my car. From cold it seems fine, idles fine etc... Once it's warmed up is when I get the problem. The revs seem to be really low and it dips up and down (all under 1k). Also when the cars running I can hear air being sucked in somewhere (sound like behind the centre of the engine), when I turn the engine off I can hear a sucking sound which lasts for a couple of seconds. I've checked the air filter, breather pipe for splits or cracks and all is fine. The car does need a rocker cover gasket which I've ordered. But I don't think this is related. My knowledge on engines isn't my strong point so any help or advice would be great, thanks.
Danny.
  Mk3 clio 1.5
noralyy this occurs when your ICV (idle control valve) is on its way out, located near the throttle body. around £20-40 to replace
