Ignition Switch Help
Hi,
Has anyone got any idea how much it will cost me to supply and fit a new Ignition switch?
I am practically hot wiring the car at the moment!
Pm me the details of your oval plate if you want the Renault parts code and prices.
Migh be able to find a procedure of how to do it yourself if I have the oval plate details
Ill need your email address to send you a pdf fitment file though.
dead easy to change and a universal barrel would be about £30 i think. pm me your details and ill have a look.
you remove a torx 20 screw,turn the key to the first line mark on the barrel face,push a metal tab in that pokes through a hole in the column to hold the barrel in place and then just slide the barrel out of the column.
could you pm me your reg number phil so i can get the vehicle details from it.
