Taken from Renaultsport website....
Bodyshell
Renaultsport Clio 172, three-door, left-hand-drive.
Engine
Sealed, 16-valve, 4-cylinder, type F4R with Orbisoud race exhaust system and catalytic converter, built and developed by Renaultsport.
Capacity
1998cc.
Max Output
190bhp+ @ 6,500rpm
Max Torque
21.5mkg @ 5,500rpm
Spark Plugs
NGK PFR6E10
ECU
Sealed Magneti Marelli MF4L ignition system
Gearbox
Sealed Sadev 6-speed, sequential gearbox, mechanical control with Limited Slip Differential using single plate competition clutch.
Lubricant
Engine
ELF Evolution SXR 5w/40
Gearbox
Tranself B90LS
Speed Meausrements (approx.)
0-100mph
10.5 seconds
200kmh-0
5.5 seconds
Suspension
Front
MacPherson strut with competition coil over spring and adjustable spring platform. Modified front anti-rollbar. Modified front subframe.
Rear
Non-adjustable trailing arms. Competition coil over damper and adjustable spring platform
Brakes
Front
Uprated vented discs and calipers using Performance Friction 97 pads.
Rear
Clio Renaultsport 172 discs and calipers using Performance Friction 97 pads. Cockpit adjustable bias, front to rear.
Wheels
All-round Speedline Corse, 15 x 7 inch race alloys, four fixing studs each.
Tyres
Michelin Control
Size: 19/57 x 15 (slick)
Size: 18/57 x 15 (treaded)
Instrumentation and Passenger Cell
Electronic Dashboard from Clio Renaultsport V6, two-stage oil and water warning lights with diagnostic capability. Analog rev counter. Composite door panels. Detachable steering wheel plus deformable steering column from Clio Renaultsport V6. Euroncap-approved Clio Renaultsport 172 fuel cell. FIA-approved fire extinguisher.
Minimum Weight
900kg without driver/995kg with driver
