Illusion - the reviews thread
This thread is here for all of our customers and members of the product test panel to submit reviews, pictures and discuss our show car wax, Illusion.
An overview of Illusion:
Detailing paintwork is the art of creating optical illusions, and in this art Auto Finesse Illusion is a true master. Made from a highly innovative blending of natural and man-made ingredients, Illusion’s sole purpose is to push the concept of a ‘Show Car Wax’ as far as it will go. Red glows like a molten pool of lava, metallic flake sparkles like a diamond in the sun, white assumes a gloss that has never before been seen, and black becomes a portal to another universe…. Is it magic, or just an Illusion?
Auto Finesse Illusion contains 48% T1 Grade Brazilian Carnauba Wax by volume, with the remainder being made up by synthetic polymers, and gloss-intensifying oils. The combination of these ingredients means that Illusion can provide 2-3 months of jaw-dropping beauty and durability. With a delicious strawberry liquorice scent, and effortless application, few want to wait that long before applying another coat anyway.
Preparing the surface:
To create the ultimate shine we always recommend that your vehicles paint work is polished prior to application of Illusion. Tripple will remove and mask any light surface defect whilst leaving behind a slick glazing oil for Illusion to bond to.
We recommend that you use a microfiber applicator to apply Tripple. Once you have worked Tripple into the panel and it has hazed over, remove any residue with a fresh microfiber cloth.
Application of Illusion:
Now your surface has been properly prepared its time to get waxing. Start by teaming Illusion and Waxmate together, then twist the Waxmate ninety degrees on Illusion. The oily nature of Illusion will insure that this is enough Illusion to coverage a medium sized panel.
Now using straight lines massage Illusion in one panel at a time. Once your whole vehicle is covered its time for removal.
Removal:
Illusion is very forgiving with its cure time as there is no set time. This makes it perfect if you are a time pressed detailer or if you are new to waxing. This flexible work time allows you to remove Illusion after waxing the whole vehicle.
When Removing Illusion make sure to use a clean microfiber towel. For this job we always turn to our Duo edgeless microfiber cloths. These offer a safer experience and have a larger work area that the standard 40x40cm microfiber cloth.
The Finishing Shots:
Once Illusion has bee fully buffed of you will be left with an Illusion on your paint surface. Its now that you will see Illusion's show car qualities shine through as you are left with a deep wet look paint surface.
Although Illusion only holds two to three months’ durability it still has out standing hydrophobic qualities. This makes Illusion perfect for a summer wax when you want rinse any dust off of your paintwork with an open end hose or for a quick snow foam and rinse.
We look forward to hearing and seeing your experiences with Illusion and results it leaves for you…
aucky
Nice stuff. I found that once cured it didn't at all remove well when using a plush MF, but came off easily with short pile :/
  Golf GT & A4 Avant
If only it lasted just a fraction longer, it would be the only wax you'd ever want to buy.
I've not used a wax that was so fool proof and effortless to apply and remove. And the finish isn't all that bad either!
Knuckles
ClioSport Admin
Balls. I just bought some of this off aucky lol!
Up to three months durability! I was expecting a month from a show wax! That's awesome.
Can't wait to get it on the civic as the clio still has desire on it.
  Honda & VW
Having not yet used Illusion I'm unsure as to the best practice for removal. Above it stated applying to the entire car prior to removal yet the website says the following...
"Once you have completed one normal-sized panel, or half of a large one, move on to another section of equal size. When you are done waxing the second section, you will be ready to buff off the wax from the first"
keen em to know which is best as assisting a friend in prepping his car for Players in just over a weeks time
Knuckles
ClioSport Admin
I left it to cake/bake on in direct sunlight for 20/30 mins and it came off fine. Was a little grabby but I was still surprised at how easy it came off.
an even layer, left to cure in the shade will be no problem for one person to do the whole car before buffing.
  182
Finally got round to using illusion today but rain put a stop to it just as i got started.
Anyway still managed to get the roof done and shall add to this this week as i need to finish the car for FCS this weekend.
Few of the products i used today.
Gave the car the usual wash process nothing much as it was all done recently and hasn't been used for a while due to me removing box and rebuilding etc so ~
Rinse, foam, shampoo, rinse, wipe over the whole car with oblitarate, shampoo, rinse, spray over with slightly watered down verso (Heard its good for removing waxes???) agitate and rinse off.
Left with this
At this point the clouds rumbled in so i cracked on and dried the roof so this was before polish
I applied a coat of my at the moment favourite Tripple (maybe a bit thick):eek:
Buffed off
Put a coat of Tough coat over the top of tripple to seal the shine in. I love this stuff but struggle to see where i have done lol
Applied but very hard to see
Buffed off and like a mirror
Onto the wax "Illusion" i have seen some of the results others have had, so was really looking forward to using this.
Smells just like AF said strawberry liqcorice.
The wax is very very soft and oily a gentle dab with the applicator picked up a fair amount of was but does go a long way. It didn't seem to cure very quick in comparison to other AF waxes. Left it for a good 10 mins before removing to which it came off very easy and leaving a glass like finish.
Applied
Buffed off
Really liking the finish illusion gives which is a wet look.
Just as i finished buffing the roof off it started to rain which fell just right for some beading shots.
Can't wait to do the rest of the car really looking forward to seeing it finished. I shall upload more images this week when i have finished.
Many thanks to Auto Finesse feel free to come and have a gander at it at FCS this weekend on the cliosport stand as my picture taking really doesn't do the car justice;)
Auto Finesse - is it possible to buy sample lots of illusion? Looking at trying this stuff but as I'm only a novice in detailing don't want to fork out for a full out just yet!
thanks in advance,
aucky
MartinR
Did you use the Illusion over Tough Coat? Not too much of an issue in this case because Illusion can be treated as a sacrificial monthly show wax anyway, but for future reference waxes tend not to bond overly well with tough coat IME.
Both good products that suit silver really well. :)
  182
Hi aucky
Yes mate i put illusion over the top of tough coat, Seemed ok and has gave a massively high gloss finish:). Worked well with desire too.
Maybe it won't last as long? Shall see how it goes.
Thanks for the heads up mate.
CrippsCorner
  Astra VXR
Right put this one through it's paces over the weekend! Unfortunately I forgot to take any really dirty pictures
but after a jet washing this is what I had...
When I opened Illusion I was meant with another fantastic smell, along with a slightly different consistency from the other waxes I've been trying. I must say it goes on like an absolute dream (probably helped by the lovely warm weather) although because of this I found a little bit too much at a time trying to find its way on to my microfibre! Meaning I did use up quite a lot of it on just these two panels. Maybe this one is going to need a proper order though :) anyway, I tried to get some 50/50 shots but it's not always the easiest with silver and the sun was so bright I couldn't actually see what the camera was taking at the time, so sorry if these are a bit crap!
Okay and here's some final shots. Glossy as hell! Must admit I was looking out the window at it all evening! Thanks AF, probably my favourite wax so far. Really easy to use and with a finish that looks like you've spent hours and hours on it!
True to form of course it rained the following day! But when I've still got more pictures to take I don't mind :approve:
-J-
  RS2'ed 172 Cup
My thoughts on Illusion:
So with FCS tomorrow I thought I'd better do a last second clean of the car in preparation.
I didn't take any photos of the was process but it went like this:
Snow Foam - AB Magic Foam
Rinse with jet wash
Decon with Dragons Breath
Wheels with Wonder Wheels purple stuff
Rinse with jet wash
Snow Foam
Wash 2bm with AF Lather
De tar - Auto Glym
Rinse
Clay with G3 Clay mitt (love this)
Rinse with open hose
Dry with big blue towel
AF Tripple
AF Tough Coat
Wheels Trippled
Wheels sealed with Armour All
Tyres Armour All
Then on to the AF Illusion.
Car to start:
Out with the Illusion:
Very very soft and oily, a little goes a very long way and is very easy to spread.
After being left for 15 - 20 min it was time to remove, I purposefully over applied on one panel, no problem... This has to be the easiest wax to remove requiring no effort at all, just a quick wipe with a microfibre.
Leaving:
Finish is super slick and reflective, and with the ease of on / off its durability as a show wax isn't really an issue as you could simply whip round the car in 10 min, have a cuppa while it cured and buff off.
In short another fine product from Auto Finesse, and one I may add to my collection to run alongside the pot of Auto Finesse Spirt I already have.
Paul172sport
  Sunflower Ph1
phew, what a month its been, with renovating my house, Le Mans and spending time with my boys the car has been negelted since last months test, but its Sunday ive chased the shade as much as possible and given the sunflower a well deserved wash.
This months test is the Auto Finesse Illusion wax. A quick look on the AF website shows this siting price wise as 4th of the 6th waxes coming in at £75 for a full pot. Previous wax tests were of the £90 Spirit and the flagship £120 Desire. Personally i found Desire a much harder wax compared to Spirit, so how would Illusion compare?
Illusion had already passed the smell test, with the woman at work comparing it to their lip balms!
So after a wash we can make a start
Before applying the wax, I prepared the paint with an application of another firm favorite, AF Tripple. (I was hoping to go for a trial of my newly bought revitalise 1&2 but time and the sun were against me today) Tripple needs no introduction and results the usual quality and an ease to use.
Now to the Illusion,
Using the more is less approach, Illusion feels oily and silky to apply, much more alike Spirit. Nice long even strokes seemed the best approach and application was a pleasure.
Instructions suggested to apply a panel at a time and cover the entire car, before buffing. My the tiem i reached the bonnet i was loosing the battle with the sun however, however needed have worried. When it came to buffing off i did the bonnet earlier to allow for the quicker curing time and all was well.
Illusion cured in a reasonable time and buffed off without feeling like you need popeye arms.
Described as a show wax leaving a wet look finish. I will be keen to see how long the durability lasts over the summer. Not personally in a position at the moment to buy multiple waxes durability may be the one point that makes me stick to preferring Spirit, however the results definately look great and if time allowed reapplications monthly wouldnt be that much of a negative.
All in all another fantastic product from auto Finesse that delivers results whilst an ease to use. Beading shots to follow.....
thanks once again Auto Finesse
Very late in the day, I know. Very busy few weeks!
Anyway, Illusion. I love this wax. Now my only Summer wax. And works beautifully over a bare base or my other fav (and as requested in this test) over Tripple.
First up, dust removal via hose, QD and drying towel, as the car was only washed last weekend and hasn't moved since.
Test location was the spoiler for this one;
With a clean start, time to prep the paint with Tripple.
Polished with a MF pad, left for a mo get a clean MF towel and buffed to leave;
You can already tell the difference between the two surfaces.
Next on to the star of the show;
Spreads so easily as it's very oily and the smell (fruity) makes application a delight for a fair weather waxer!!
And buffed to a very deep glowing shine.
Love this stuff and great to have another test pot in my repertoire!
And the final beading shots. Lovely glassy beads from the great wax.
Thanks again to Auto Finesse for the ongoing pleasure of test panelling!
Cheers all,
Jamie
Cheers!
