Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I cant take any more, theres a loud rattle/vibration near the front clocks at the top. Its making my ears bleed, Its so loud i can here it over the stereo.
9 screws = 3 on top in vents 2 blow clocks, top of steering cloum just clips off just give it a tug 3 behind passenger side trim 1 behind drivers side trim which just clips out then there are the 2 panels which go up the side of the window each has one clip near the top then the dash will pull towards you the lift out through passenger side door easy take ya 10 - 15 mins tops :rasp:
Taking the dash top off is piss easy - there was a guide floating around on CS somewhere. I had mine off myslef 5 or 6 times for headunit installation, I was initially concerned I'd create more rattles by not refitting it properly but that was never an issue. Siliconed my airvents near the front to stop them vibrating, used a lot of felt to stop any plastic-to-plastic moments where possible. Worked brilliantly.
