Imobiliser flat battery
I cant see why it would, Its just like disconnecting the battery for a period of time to work on the car, never had any issues doing this :)
New battery fitted and it still doesn't start.
Turns over twice then cuts out even with the key fully turned.
Doors lock/unlock, lights go out on dashboard and you can hear the fuel pump whirring when you turn the key.
It was solid red, however i think it's sorted now.
Checked all ecu fuses and there fine, turned key and left it for a minute then took it out and it then started fine.
Locked up unlocked and restarted 3 times and touch wood it's ok.
