Induction Kit questions...
Car  Megane 225 Arctic Blue
Debating about fitting an induction kit as one of the things about my Cup I dislike is the low down acceleration and have been told this should improve things.
Firstly is that correct?
Secondly, there seem to be three obvious options open to me. K&N GenII Induction kit, Pipercross Induction Kit and Pipercross Viper induction kit.
What are the differences between the three? Standard Pipercross seems the cheapest, with the Viper kit the most expensive.
Advantages and disadvantages of each one?
Andrew
open filters loose power on the F4R engine (unless relocated/shielded for engine heat)
an indution kit wont do much without a relative ECU modification in my opinion
it worthwhile remove the CAT also
best to get an closed induction kit, remove the cat for sports cat or bypass pipe, full system, then remap the ecu.
why not get a panel filter and then re-route the OE cold air feed, basically getting you a closed induction kit for about £50
Thanks for the posts.
Think I might give this one a miss as am reluctant to start messing around with the ECU or removing the CAT - I smell insurance and emission problems :)
However IF I did go that route, what ecu remap should I look at?
phoenixy - you mention a sports cat system? Not seen any systems with these, just cat back or no cat at all.
I assume the Pipercross Viper is a closed system and the rest are open? My technical knowledge of cars is limited :)
BRUN - how would I re-route the cold air feed? Simple words please! lol
Andrew
basically take off the ducting what the OE air box uses and get some flexi hose and put it to a better source of cold air
The OE airbox uses a butterfly solenoid/valve to close one of the cold air pipes when the engine rpm is low to help low down torque, Ive got an ITG Maxogen kit which is regarded as the best closed induction kit on the market for the 172/182 and I dont think its really helped low down torque anyway, it feels better after 4.5krpm Id say but not low down, after all, it is a 16v engine so dont expect miracles anything unless you keep the revs high in the power range.
Im looking at getting a K&N Generation II kit, they look fairly good, or I might just put the standard airbox back on with an ITG panel filter, Id say thats one of the few good cheap options for the 172/182s....
If anything my 172 occasionally feels more sluggish below 5krpm with my maxogen. Could be my imagination, but it does seem to pick up slower. Hopefully a remap will sort that a little.
[Edited by lagerlout1 on 31 July 2005 at 7:29am]
