Injector 2 short circuit to +Vbat
Car  Looking....
Basically the engine started misfiring and engine light started to flash.
Plugged the rstuner in and it came up with the above fault.
Anyone else come across this before?
Possible wiring fault or just a injector needs replacing?
@MJRacing
Im not 100% mate, but id clear the code, swap an injector from another cylinder,
Let it misfire again, plug it in, if the fault code moves to where you got the swapped injector from and number 2 fault doesnt appear
It could point more to the injector, if it stays in the same place then its ruled out an injector and could be wiring like you said
@Hodgins Cheers mate, already swapped over and just replaced the faulty injector. Been out and all seems fine now, running great and no lights on.
Hopefully sorted now and no wiring problems, I fecking hate electrics.
