Injector failure on same cylinder
Car  Ex 182 owner
Out of interest can anything Cylinder Number specific keep killing injectors?
Month or so ago, Had a miss on No3. did all the checks and ended up swapping injectors 3 and 1 to test. Tried again and hey presto the miss moved to cylinder 1. So I bought a genuine new injector from Adam, installed it in No1(so the old no3 was removed) and problem was solved. Car didnt run much as it was now out of MOT, probably 200 miles max over xmas.
Started the other night and miss again. I didn't have access to my code reader so went straight for the pulling the leads to each injector. Once again miss in No3. (the old No1 from above swap). Swapped it with No 2. and once again the miss moved to the No2. cylinder.
So I am looking at getting another new injector.
Now I apprciate that I may just be unlucky and that the 2nd failure in No3 didnt involve a brand new injector. This time I will defo swap them back so the new one will go into No 3.
However before I risk a £70 part, is there anythign else which might be causing the injector problem to start in No3?
Thank you
Chris
injectors are only 30 eah on ebay,same as renault ones m8 if it helps
Thnk you,
Are they the same manufacturer? I thought i read on here injectors were one thing not to go down the ecp/gsf route.
yes genuine injectors mate,im no mechanic but are you close to any specialist on here,other than that for 120 quid you could replace them all
ecp and gsf its the same stuff on a lot of stuff mate as bloke said,its just bleedin a lot cheaper
Cheers All, I guess for half price its worth giving them a go.
as bloke said probably just unlucky. Unless anyone knows of any other poss reason.
I try to go renault when reasonable, especially thru Adam..I do some bits from gsf/ecp.. £55 for a genuine renault washer pump for instance was one of them moments. Just trying to balance whats worth the extra and whats not.
I am fortunate that its a toy, cos the damn things been near side lined for 2 months now. Home mechanics in winter without a garage is a complete arse ;)
for 30 quid each id try changing them,new injectors should give it back its va va voom
I got my injector from euro car parts and it was made by the same company as the genuine renault ones (magnelli Martelli) or whatever there called
Eurocar parts supply Genuine Renault injectors which are made by Magneti Marelli. (IWP 0042)
These can also be bought new from Renparts from there ebay store
http://www.ebay.co.uk/itm/Renault-C...arts_Vehicles_CarParts_SM&hash=item46170fe9f5
