I used oem which are robust, came with the new inner from renault parts direct. I just had a look but couldnt see the gaitor on its own perhaps you can get them separately if you enquire?
Yeh to be fair the full kit from Renault isn't a bad price. But it'd then mean paying for allignment and a tool to get the rod off, which currently has no play in it
i just used a generic gator, been working fine for years, if theres no play on the inner joint then take the ball joint out the hub, crack the locknut and count the turns that the ball joint comes off... reverse to put back, if you out by any half a turn when putting it back then you should feel it, just get it re aligned...
