133, 182, Kangoo 182
Planning on starting my install tomorrow but just want to clear up the steps before starting.
I have two components, tweeters, crossovers, subs, an amp and cap to put in.
The two subs, amp and cap will be in the boot (this will later be replaced with a single sub stealth install - just using what I've got for now) and the comps, tweets and crossovers are going up front. Rear speakers are being completely removed (..at least, for now).
1. Speaker wire.
I understand speaker wire needs to be seperated from the power cable. If I run the RCA cables and speaker cables down both sides and the power cable down the middle this would be ok? How much trouble is it taking up carpet to get it all in?
2. Ground cable.
Where's the best place in the back of the car for this?
3. 6.5" comps in doors.
They're not very deep speakers... would I simply need to create some MDF rings for these to fit or will I need to hack out some door for the magnets?
4. Power.
The amp is a 2KW amp. As stupid as it sounds, I don't really plan on using this install all that much. I know this is going to kill my batt/alternator but will I be OK using standard until I can actually afford to replace these? Read about split-charge systems - does this require a new alternator to help charge?
5. Think I can do it?
Full weekend and first ever install. Plenty of guides here to help me with certain bits but I'm not entirely sure if I can actually get this all in myself!
Thanks for any comments (even bad ones :/ )!
1. Speaker wire.
2. Ground cable.
4. Power.
