installing bucket seats
  clio 172
Going to start installing these in abit.
anyone point me to any guides that others have done when istalling ?
seats are removed etc
Struggler
  Ph1 track 172
nothing to it tbh,
build everything out the car (seats, subframes, pretensioners if your using standard seatbelts, or just feed them all through if you're using a simple buckle harnesses)
worth having two people involved also if you have to do the nut and bolt up at the same time
  ur megane r26
I have cobra imolas with the extra low subframes, can I build them up using the standard renault gear so I can still use the standard seatbelts for the time being?
  ur megane r26
well i have read about taking all of the bits and bobs off of the bottom of the standard seats and building it all back up onto the buckets, this would only be a temporary thing as want to get harnesses and that but cant atm
Struggler
  Ph1 track 172
if you have the seats and the subframes, what else would you want for the clio??
pretensioners to use with standard seatbelts?
