Interior clock
Car  Clio 1.5 dci 65 2002
Hi there I have got an Clio 1.5 dci 2002 and the interior clock has be pushed back, I was wondering if there was any way of clipping it back in without taking the dash out, if so how hard is a job and how time-consuming :)
many thank Joe
Nope afraid not
Take the top dash off. Would be able to have it done in 10 minutes if you follow the the instructions in the "Guide" section.
I dash is very easy to take out
how to do
1: Peel of the trims above the glove box, the one right of the steering wheel and the one on top of the steering wheel.
2: Undo all srew 3 under glove box trim, 1 under the right of the steering wheel trim. And 2 under the top steering wheel trim.
3: There are three srews on the top De-mist vent undo them far left, in the middle and far right
4: you will have one srew on each side of the dash (if the doors closed you can't see them) undo
5: pull the seal of the door ( will come off but be carefully)
6: pull the pillar trims off (pull at the top then put a srew in to release the trims)
7: tap the dash upwards, make sore you pull toward the back of the car aswell.
8: when dash comes off take it out the nearside door ;)
put it back together is easier then removal follow in 8-1
