Interior Panel Removal
Car  ITB BG 182
Right, the panel that run along side the seats near the sills.
I know you can lift them to put small cables under for hiding them, yet 0awg (50mm jbl cable) will not just be tucked under.
So on the left hand side, how do we get the cable under there? Also having problems getting it past the passenger seat bit and is it easy to replace?
You have to undo one screw along that plastic strip and you can just take the whole thing off, makes it much easier, and you should be able to fit it down there after you've taken it off. Then just put the plastic bit back on a screw in the single screw ;)
Ok, I know that on the little bit of plastic attached to the passenger seat, there is a little hex screw in the back. Like in the picture below.
The long plastic piece that runs along side the door, the bonnet handle holds it on. But what else?
There's a small screw in that, also near where you've highlighted iirc.
I'm pretty sure you need to remove the rear door card to get to it but you might get away with just removing the seatbelt and pulling at the bottom.
No.
You just need to remove the bonnet release handle. Undo the large torx bolt that holds the bottom mount for the seatbelt, and remove the metal thing.
Then just pull up the door rubber along the bottom, and pull it off. Its just plastic clips on after that.
