intermitant squeaking on a 182
Car  silver clio 182
Hi guys getting slight squeaking under accelration Im not sure whats causing it Im drawen away from belts however as it only happens under accleration in 2nd and 3rd gear mostly never whn revd out of gear or when the clutch is pressed is this a common fault or has anyone experienced this previously cars on the 50k mark belts done at 36k
Hi, I'm having the same drama, 182 just passed 50k, belts are fine, squeaks under harsh acceleration, above 5000rpm sounds like the valves are about to come out the bonnet?! Have you managed to find out what the problem is?
