Intermittent Miss fire 172
497adam
  clio 172 phase 2
Hi my 172 has developed a bad miss fire, this morning was fine for about half a mile (engine just starting to warm) then it came back. Its quite a bed miss. Any ideas?
Its had plugs (correct ones), magnecor leads and lambda in the last 8k and other than being due an oil change is fully serviced up.
What are your thoughts guys?
497adam
  clio 172 phase 2
could this still be coil pack? and am i best getting genuine one?
maynard
  ph2 172 track car
We stock OE Valeo and Beru one's. I'll drop you a pm first thing in morning.
  Clio172 / Focus Ti X
Injector circuit possibly! with the car idling, unplug them one at a time, if the car struggles even more when you unplug one then that one is working fine. If nothing changes then its that injector circuit giving you hasstle. Do this with all 4.
By circuit i mean it doesnt have to be the injector itself, it could be a broken wire or something, to eliminate this, swap the faulty one with one that works, the problem should have moved to the cylinder you placed the faulty injector in. If its still on the same cylinder you took the suspected one from, the problem is with that circuit.
497adam
  clio 172 phase 2
Thanks for advice guys, off to birchdown shortly (if i make it) just havent got time this week to try and sort it. but if the 2 kevs cant sort it this afti will have to get stuck in on sat
