Intermittent no start situation
  Clio 172,Golf VR6
Hello. I'm having some problems again, a bit of a weird one.
It can work fine for a couple of days, then not at all.
it will crank for a couple secs when it decides to not work, but the cut out. Sometimes, i turn it over a couple more times and it starts right up, sometimes id cranks for two seconds a million times until i drain the battery.
I found out today if i disconnect the battery for a second and connect it back, it starts right up.
Immo light isn't on, or flashing either. It stays off all the time.
Thinking about getting rid of the immobilizer, anyways, does the UCH carry the code too, or is the ecu the only one that needs to be removed from?
