Irratic idle after fitting k-tech induction kit
Car  172/B8 Quattro
As title, I'm getting the idle dropping up and down when went for test drive after fitting induction kit
is it the ecu learning? Or is there a reset procedure
I believe the ECU will reset if you disconnect the battery for a while. I'm not sure that will solve your problem though.
Make sure there's nothing blocking the pipes etc. Like a piece of cardboard or packaging!
Thanks lads,
Dmallet- it's not that bad tbh, I just went for a test drive after fitting (round the block) and noticed coming to a junction where I press clutch the idle rised a bit then went back down (not low enough to stall)
Im sure it will learn itself after a short time as the airflow has now changed but not 100% sure if I'm honest
Cool, I'll check tmr but I'm sure everything's on right, not exactly a big job fitting one lol.
it only had a 5 min drive so I'll give it a good run tmr.
thanks for tips and advice.
