Is changing the air filter a job for an idiot with no car knowledge and a couple of screwdrivers, or should I just let my local garage do it while they're fitting me a new exhaust? If so, briefly whats the order of unscrewing/ rescrewing?!
They are torx screws so you need a T30 torx bit . You can get away with using a flat blade screwdriver on a torx screw but its always best to use the correct tool for the job . Just an example of what they look like . You can usually pick up a cheap set for a few quid .
