Is it driveshaft???
Car  Ph1 172 (titanium)
On sunday I wanted to check my spacers bolts were all ok, so I whipped off the wheels quick!
Now the few days before I had noticed some noise from the front end, so had a poke about..
When jacked up, spun wheel round, passenger side fine, no problem,
Jacked up drivers side, spun wheel, clicking sound when spinning, which speeds up as the wheels was spun faster,
Seems to be on the gearbox side of the shaft, rather that the hub side,
Is this shaft related, or box related?
Its common on high milers for the inner cv joint to go on the drivers side driveshaft. Normally if its this you'll also feel a wobble through the steering wheel while at high speeds/accelerating hard, if its really bad there will be play in the joint.
I've not got any wobble through the wheel!
This shaft was only replaced with gen. part in November or so.
