Is it ok to use petrol/wd40 to clean a throttle body?
Paddy_g46
As above really, don't have any brake/carb cleaner and want to get the job done now if possible and petrol or wd40 wont be a problem?
  SQ5
Yes you can. I hope your taking it off though?
Best off splitting the throttle body down to its components and cleaning all and rebuilding. I did and have never had any problems.
  SQ5
I could do. I have a spare throttle body that sticks. I'll strip one down and photograph it during the week :)
jenic
Cheers, seems something quite a few people are told to try when having problems so would be useful :)
  53 Clio's & counting
I did a thread a few years ago on removing and cleaning/lubing a ph1 tb, its in the guides se tion :)
Paddy_g46
Ok, iv just taken it off and inside is pretty dirty, also iv noticed that the butterfly doesnt seem to be shutting 100%, iv got a couple of pics here. Should it close completely flat is in 90degrees to the housing? ImageUploadedByTapatalk1341147633.055027.jpgImageUploadedByTapatalk1341147656.337682.jpg
Fancy making a guide for the forum Danny? :eek:
I'll try and sort something out. I'll start writing it this evening!
http://www.cliosport.net/forum/show...ng-revs-jerking-on-light-throttle-on-your-ph1
Is yours a ph1 or ph2? Icant see the pics at the mo.
It should spring back yes
Id like to see a guide.
Get it done Danny!! :D
Flol am I invisible? :eek:
Paddy_g46
Ph2, right all fitted and the car idles perfect now (touch wood) at about 800rpm, needle sits perfectly still whereas it used to be up and down like a yo yo. After i had a think about it i came to the conclusion that if the butterfly was to shut 100% then it wouldn't idle because no air would get in?
Paddy_g46
Yep spot on, cheers for the advice everyone.
Also gave my panel filter a clean and oil which probably helped!
