Is my external HD knackered?
  UR R26R.5, VW Golf R
Loaded up my computer earlier and plugged in my Freecom external harddrive. Its not showing up in My Computer, and the drive itself is making loads of weird 'clicking' noises and the 400GB light on the front just keeps flashing on and off at random intervals. Whats happened? Is there any way I can get the information off it? F*cking useless thing.
Its finally stopped flashing and clicking now so I've gone into Explorer and tried clicking E:\ and it says, "E:\ is not accessible, The Parameter is Incorrect.
WTF.
Help :S
KDF
  Audi TT Stronic
Sounds fucked to me.. you might catch it on a good day and be able to retrieve your data off it.. but if you do get any access to the drive at all then make sure thats your first priority.
I have a 1TB external drive (well actually I have three ;) ) but they are all set to 500GB mirrord raid.
Cant I use a caddy or something to get the data off it or something stupid like that? There are some files on there that I need. Great stuff. Only had it a couple of months.
KDF
  Audi TT Stronic
if its clicking it sounds like the hard drive controller board is fubared.
Taking it out the enclosure and connecting it to your PC directly is worth a try but I wouldn't get your hopes up.
  A4 Avant
try repartition, reformat and then use a data recovery tool?
I wouldn't reformat or partition as you may write over the data you want save!!
I posted in gareths thread about some software that may be able to recover your data. Search for that. It recovered all my data.
I normally take the external drive out of it's caddy and then plug it directly into the motherboard using either ide or sata cable.
  A4 Avant
If you go into 'control panel', then 'Administrative Tools', then 'Computer Management'. Click on 'Disk management'. Are your partitions listed there?
If not, unplug your external drive and with the above window still open try and plug it back in again.
No nothing is displayed. The external HD is just sat here with the light on the front (400GB) flashing on and off etc.
  Fiesta ST
If theres a clicking there might be a stuck head - sticking in the freezer can help contract the metal bits and may unlock it - seal it first though as you dont want freezing particles on your HDD.
What do you mean put it in the freezer? How long for and wrap it in what? Will this destroy all the data on there or is that safe?
  A4 Avant
I'm always wary about the freezer thing. I've heard of people getting it to work but the drive totally failing soon after. I'd use it as a very last resort!
  Fiesta ST
Indeed. Well I'm getting nothing at the moment. When I load windows and plug the Freecom HD in to the USB port, it spins up and then clicks for a while. Eventually the light on the front starts flashing randomly. Before it was crackerjacked, as soon as I plugged in the USB I'd get an onscreen message saying about transfering my files. I get nothing now as if there's nothing even sitting there. It has loads of important stuff on too. So... I either need something to recover the data (and software wont help unless I've got a caddy or something as I cant see the HD to recover the data) or the freezer trick which I am wary about too!
  A4 Avant
Try and get your hands on some disc recovery software. If windows won't even recognise it i'm not sure if the recovery software shall either?
I dont even know how to get the caddy off this Freecom device. There are no screws or anything?!
  Clio 172mk2
try shakin it about if nowt else works , some times it`ll allow u to use it for a hr or so before it fecks up again.
but is there really owt that inportant on the drive
  Clio 172mk2
^^ wtf ive had a seagate that lasted a year ,
and ive owned 6 maxtors oldest is 5 year old and still working, only had one break n that was down to circuit shorting out on a screw on me desk.
