Is my valver a 2litre?
Car  Rover 200 Vi
Just bought a rotor arm for my 1.8 16v which turned out to be the wrong one. Took it back and found that the only one that fit was listed for a 2litre williams. Had a new(ish) engine fitted not so long ago and it does go like the clappers! Could I really be packing bigger engine? It looks identical to the old one?
they do look identicle, however im sure hte rotar arm is the same?? does your car have a kick at 4000rpm? if it does its a valver, alternatively get a mirror and a torch and try and look at the engine number it will be on the right off the block at the front if you were standing infront of the car.
the rotor arm is the same mate on both of em, they must have given you one from a 1.8RT or something, the dizzi cap is the same aswell
pretty sure its only a 1.8, it is fast but recon I wouldnt have lost to a Civic Type R with a full two litres!
