Took my drivers side wheel off and noticed the inside was plastered in green sludge. Its like grease.
Is this shock absorber fluid? Ive been running apex on standard shocks for over a year.
God I swear Im gonna burn this car out and screw my no claims....
Steering feels like its got free play, I can wobble the wheel while driving abotu half and inch eather way without affecting direction massivly.
Feels like it lurches a bit in some corners.
Have had a little creaking from the drivers side (thought it was the top mount) when on a hill and using almost full lock.
I hardly drive it these days so aint noticed too much...
Ahhh crap I bet I know what it was! I was turning around in the mini industrial estate behind my house. Theres two loading ramps side by side with a slight height difference between em and the drivers side clunked down onto the next level of one of em... fudge it must have been that
Expensive job to replace?
^^^Possibly, possibly not. It would depend on the angle at which you hit it.
My CV had a habit of popping every couple of hundered miles and spilling its' insides all over the shocker, caliper and wheel. When secured properly using a proper tie I had no further issues.
Don't try a cheap tie from a motor factors, they don't have the strength to seal the CV and stay put under heavy load. If it is just the tie, take it to a garage and ask them to re-grease it re-seal it, probably no more than £20.
As for checks, have a look at the boot for splits or even if it is attached properly, you will know what I mean when you check.
Turned right up onto the ramp facing the white building, reversed away from the camera on almost full lock and the wheel bumped down that little gap :S
Should I look for a rip in the rubber cover or something?
It could have popped off if you gave it a good whack.
You need to be looking for a split anywhere around the circumference of the boot but, as Brian said, it would need to be seriously split to spill that much grease.
My money is on the fact that it has popped off. Even more likely if your car is lowered.
Dependant on how long it has been spilling its grease, you may well get away with re-greasing and re-sealing/fitting a new boot and leaving it at that. It's alway worth giving that a go before full replacement due to the costs involved ie. new CV is muchos dinero, new boot and grease is peanuts.
Thats good to know. It was a few days ago but I could count the number of miles its done on one hand thank god.
I wouldn't have even known if I hadn't taken the wheel off on a whim!
You should be fine then mate. Keep it dry and have a look ASAP. You would have soon known there was an issue as the grease began depositing itself down the side of the car.
