is this the correct ABS ring?
Need your help guys!
Someone from the forums has kindly offered to fit a new abs ring very cheap so i was wondering which part i need to buy...
Is this the right one?
http://cgi.ebay.co.uk/ABS-Ring-To-f...oryZ9886QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Does anyone have the renault part no? as far as im aware most renault mechanics do not know where to look for the part no and can only find the complete unit with driveshaft... but the individual ring is available.
Car is a 2000 MK2PH1 1.6 16v RSI
Thanks,
Ahmed
C
cliosportheth
i had this same problem mate,aparantly renault dont actually sell them seperate from the driveshaft so that they make more money off them,however dont dispear i found a shop which tracked some down for me and cost me about 10-15quid each depending on the amount of teeth and diamiter of it,a any anymore cos the shop closed down but ya can buy em seperate if ya look hard enough,hope this helps ya out
After some research i found that renault appear to stock them, diagnostics software tells me the part number should be
77 00 867 344 RING D/SHAFT ABS
but ill confirm this with the correct details for my car tomorrrow
