Issues RE offset??
Da
  Less
Now I know the 182 is ET45 as standard, so if I was to fit ET37 wheels on my car which at present is standard would I have any real issues?
Also I may be adding Eibach Sportlines if I can get hold of any. I know the drop isn't massive but would this cause any issues?
Cheers :cool:
  tiTTy & SV650
shouldnt cause any issues at standard height. May depend on the wheel design too re. clearance when lowered? I dont think there'd be any issues on a 30mm drop - I'm pretty sure its been done many times over
  lift number 1 @ btm
with et37 and lowering you will have rubbing with 50 profile tyres, but 45 should fit ok, or at least that is what i found.
  tiTTy & SV650
ph 2 172 and 182 are different though, different offsets as standard and different track, hubs etc so may be slight differences in clearance.
