ITB fitting enquiry - need help
K_McDermott
Car  Megane 230 r26
Hi guys, need some help,
currently on with wiring in the ATPower itbs.
got the TPS on the rail on the ITB themselves pictured.
ive been supplied a plug with the wrong end somehow, this plug has the correct wires out the piggy back ecu, but isn't correct for the sensor,
joys of buying used i suppose.. i need to source a plug connector for this.
my question is, which is the wiring we need to use from the oem ecu for this.
im assuming its from the 182 throttle body loom plug, just not sure which ones, the descriptions are hard work on my wiring pin out.
