ITB'd 182 MOT time!
  TrackCar & F30 330d
I'm having a bit of a blond day today and cant work out if my ITB'd 182 will pass its MOT on emmisions when i bash the cat back in?
It passed last Feb when it was standard but now its mapped with to the ITB's so will it pass?
:S
DMS
  A thirsty 172
It should pass with a cat I would have thought.
IIRC they only test it on idle and at a couple of thousand RPM. I may be wrong though.
  ITB'd MK1
should do, it's running lambda, all it might need is a bit of ignition timing tweaks to make sure the cat gets hot at low rpm, but they're normally ok :)
Brett
  172 Cup, M2 and MCS
Just leave a crate of larger in the boot. That may make it pass ;)
  alien green rs133
take it for a stonker of a drive before the test to get the cat upto temp.
they start working at 350 degree's C
  Coupe/Defender V8
You might get away with it mate if you give it a good thrashing before hand..i'd be interested to know actually! with and without ;)
