what are the espace airboxes like? do they fit straight on 172/182's? i was lookin for a ph1 172 box but proving hard to find a decent one. got offered one off salvage website for £75 inc delivery - u think its worth this?
The ITG panel does sound slightly different. It gives a very subtle little whistle and sounds cool. Powerwise you'll not really notice anything, but apparently it does give a slight increase. What it is good for is using with other mods if you have any planned. It allows much better airflow so will support other engine modifications well. And it'll do that for a fraction of the priced of a decent induction kit.
As has been said, if you're going to go for an induction kit make sure you get a good enclosed one as open ones are largely ineffective and often worse than nothing.
What you could do if you're not up for spending £350+ on a Maxogen (the best kit for the 172/182) is get the panel filter, take the acoustic valve off (or leave it connected but take the pipe off as you'll then avoid issues with warning lights) and feed the pipe out through the front for cold air. You could then cut another hole in the airbox and feed another large diameter pipe up to give you more cold air flowing in.
Dont want to sound too much like a spazzer, but what is the difference between a Viper closed i/k and a panel filter in the standard airbox?
Surely its a foam filter inside a container with a pipe at each end? Or am I missing something which justifies an extra £250:S
I know where theres 2 phase one airboxes![]()
Seriously, i dont know why folk get a stiffy on about panal filters and ph1 air boxes. If they were that good they'd a been bolted to the next generation ph2's and 182's !
