Its leaking all over me!
Car  Civic Vtec y0
There is a leak coming thru my roof!
The water is coming out between the sunroof winder thing and the rest of the panel (If you know what I mean!?)
What could be the problem?
blocked drain holes,!
Open the roof look in the channels, clean all the gunk out and push a thin piece of wire down the drain holes (welding wire is ideal) make sure the water runs out under the wheel arches and not inside the car.
when you have cleaned/unblocked them. check they run clear by pouring water into the channels.
The channel is the groove that runs all the way round the sunroof hole.
The drains are in the corners of the channel.
