Which part of the rear beam should be used to avoid bending the usual jacking points by the sill? Can it be anywhere along the beam or are there stronger/reinforced areas along the beam? So if changing a driver's side rear tyre can you just place the jack under the beam on the driver's side and raise the car?
Thanks.
Thanks.
