Jacking the Car using the Rear Beam
is1
Car  Integra Type R DC2
Which part of the rear beam should be used to avoid bending the usual jacking points by the sill? Can it be anywhere along the beam or are there stronger/reinforced areas along the beam? So if changing a driver's side rear tyre can you just place the jack under the beam on the driver's side and raise the car?
Thanks.
I always used the rear beam. Big fapping strong bit of metal !
Just use some (I won't call it common as it isn't...) sense and you'll be fine ;)
Remember to put it in gear if you're only jacking the back up !
:evil:
