Jms remap or Rs tuner
Car  Clio 182 cup
Got a SS cat back system on my 182 and got a decat fitted as well but I'm disappointed that it doesn't pop and burble on overrun. Does anyone know if the Rs tuner remap will make it pop more etc or go to Jms for the pop and bang remap as I can't see the Rs tuner has a map like this :(
just remember not to use over-run when you put your cats back on, itl kill it off a lot quicker. rumour has it cats arent cheap
If you want pops and bangs on a 182 then you will need to get the map from JMS or anywhere else that can do custom cals as the Rs tuner still hasn't got 182 pops and bangs in the shop.
If the "pops and bangs" map is what you want go to JMS and get a custom map. If you want to try it out then get the RS tuner, can always switch the map if it's not to your liking.
JMS have a great rep on here so that a +1. The rs tuner you can check faults and that has paid itself pretty much so its up to you.
The over-run map is addictive. Decat and strait through middle section = LOUD bangs... and pops. I highly recommend it.
As above really. We provide it as a bit of fun, however if for any reason a customer decides they don't want it, we remove it free of charge so its effectively the same deal - simples.
