juddering noise when pulling off
when i pull of slowly in first i get a kind of juddering noise under the car?
like underneath and infront of the gearstick.
thinking it may be one of the lower engine mounts, gear linkage or the exhaust?
already had the top drivers mount replaced recently. is it quite likely that the others are due to die?
Waitey
  Alpina D3, AC Cobra
Yeah. I had this when both my nearside engine mounts broke.
Waitey
  Alpina D3, AC Cobra
Get hold of the engine and see if you can rock it. Or check them visually. Mine were easy to spot as the mount under the battery was in half as well as the subframe mount!
