Eh? When a speaker is driven with a high powered amplifier to high levels, there will be a significant amount of current flowing through the voice coil. Since the voice coil has resistance, there is a voltage drop across the speakers voice coil (which the amplifier appreciates greatly). This means that there may be a great amount of power being dissipated (in the form of heat) in the voice coil. When a speaker is driven with lots of clean power, the cone moves a great deal (in proportion to the output voltage from the amplifier). For speakers with vented pole pieces, this movement forces a lot of air to flow in the magnetic gap (area where the voice coil rides). When the woofer moves out of the basket, the chamber thats under the dust cap and around the voice coil expands which pulls cool air into the magnetic gap. When the woofer moves in the other direction, the chamber size is reduced and the hot air is forced out of the vent in the pole piece. This air flow cools the voice coil. If a relatively low powered amplifier is driven into clipping (to a full square wave for a lot of people), a relatively large portion of the time, the voltage delivered to the voice coil no longer resembles a sine wave as it would with an unclipped signal. While the amplifiers output is clipped, this voltage may be considered to be DC. No matter what you call the clipped part of the waveform (DC, not DC...), the voice coil is not being motivated to move as far as it should for the power thats being delivered to it and therefore is likely not to be being cooled sufficiently (since the speaker is driven by a linear motor, the voltage applied to the voice coil determines how far the voice coil moves from its point of rest). Hence you get a f***ed speaker. It moves LESS far not further.
