just hit a curb
  2003 172
Hello
because of the snow, i skided into a curb and somthing snapped. basciyl i can move the front wheel left and right so its touching the arches. what could be broken?
as you can see on this pic the wheel is basicly touchign the front bumper
then i can move it to the left so its touching to arch
thanks
  BMW M135i
Doesn't tend to do the chassis mounting points much good either. I bent one a lot less than that and it was never 100% right again.
mgoode180566
  172 Sunflower
snap !!!!!!!!
just did the same myself. understeered into a high kerb on petrol forecourt.
slight front bumper, wheel, mashed foglight and damaged wheelarch liner.
steering to the left heavily. checked one side to the other and the bottom arm is bent :(
could be worse i guess.
where is the best place to get a new bottom arm ? seen them for £50 on fleabay.....
  2003 172
my machanic had a look at it. he said it needs a new wheel, lower arm, ball joints and get tracking re done. should be about 200£
CrippsCorner
  Astra VXR
I've done this to a previous car, cost me about £950 to sort out. Almost a write off, although mine did look slightly worse than that. Fixed it but as someone already said, was never the same again.
Might be worth cutting your losses mate, have you asked advice at a garage?
mgoode180566
  172 Sunflower
I have been checking some old posts and have noted that the subframes suffer when attacking kerbs.
I have had a quick check side to side on mine and as far as i can tell it all looks good.
When a subframe bends from a heavy kerbing where does it tend to bend\twist ?
Alastair.
  986'S 172ph1+182FF
lol i nearly hit a curb coming down my road a minute ago, i braced my self, 1 inch from hitting the curb i went over a drain and it chucked me across the road lol was wel wierd
  Ph1 172 + Combo van
I done the same just before new years eve in my saxo.
Wishbone was bent like a farking bannana. Needed a new alloy,tyre,wishbone and stabiliser rods.
mgoode180566
  172 Sunflower
you lucky lucky lucky b*****d ! ( read this is Pythonesqe voice ! )
  Clio 1.2 Billabong 53
You have done exactly the same as me. My passenger seat airbag went off aswell tho.
Getting it sorted tomorrow, hoping its not going to be too expensive!
mgoode180566
  172 Sunflower
Ordered a new bottom arm for mine today. Should be a straight swap.
FYI the arm was £54.90 + vat
