hey, ive just got a k&n bolt on kit from a mate. i tried to remove the orginal standard air flow box off the carb, and the bolt on seems to fit on the carb ok, but is resting a bit low.
wanted to check to see if any one knew if it was ok to fit a bolt on kit like the ones here: http://cars.potn.com/default.php/cPath/2164_2282_3145?PHPSESSID=33f8b3513d175e871da762d2502eac6bhttp://cars.potn.com/default.php/cPath/2164_2282_3145?PHPSESSID=33f8b3513d175e871da762d2502eac6b onto a 1.4 MAXI. I think i need to get a piece for the bolt on to rest on so that its not fitted to close to the engine and probably a better cold air feed to the filter its self.
cheers.
