K-Tec ITB conversion...
Christopher
  Z4M
It looked fantastic! Well done K-Tec.
I wish i had took more pictures of it... Dave, Mark and I were admiring it for a while! Proper job. :cool:
http://www.k-tecracing.com/show_product.asp?id=2478
Drive in/Drive out fitment too. Any idea of real gains? The site says 30bhp increase.
I've emailed them for more details... just a thought. :eek:
Anyone else know more about it on here? Thoughts?
Owen
ClioSport Admin
Looks good!
Be interesting to see how it works out cost wise with the GDI ITBs (assuming you spec the wilder cams etc).
Something I would love to do with mine, but the sensible side of me is telling me to save for something faster out the box.
Christopher
  Z4M
I'll let you know the answers, i've sent them a lengthy email. LOL
It did look fantastic though, really professional.
  Sunshine Bus ph-quick
It did look mint!!! Really neat & looked like it was *meant* to be there not just stuck on.
Do it!!
M
mini-valver
Agreed, looks so so much tidier than the other installs there, no birds nest, heatshrinked and connecter blocked wiring and cable ties holding everything in place and a proper catch tank.
You need the white cam cover and ITB's in your life Cwissy.....
Christopher
  Z4M
Agreed.
Real alternative to DC5 ownership though? Hmm.
Can you imagine someone else not looking after your car the way you do & you being okay with that? LOL..
I'd go for it...
M
mini-valver
Agreed.
Quicker than one, cheaper to insure and tax, no more outlay......
  b/g 182, meg tourer
it looked like a good kit. short trumpets, so im not sure how much tourqe they will give? smaller radiator would be a good idea with it too. i need a good read up on it. considering tb's :)
ForceIndia
  Gentlemans spec 200
Agreed.
K-Tec Racing
ClioSport Trader
  172LBT-172HBT-197-R2
Thanks for the feedback about the installation on the car. We should be able to start getting cars in for the kits to be fitted within a few weeks. The fitting cost for the kit will be £450+vat and other parts such as cams can be added to help gain more power.
As soon as the kits are in stock the website will be updated.
Just for those interested the spec of our new demo car is:
KTR Renault Clio 172 Sport
Sadev 6 speed sequential gearbox with custom mounts £4800 approx
KTR Titanium 2.5" cat back exhaust system £lots!!
KTR straight through 2.5" bore dcat pipe £125
KTR throttle body kit (see seperate sheet for full kit details) £2380
KTR gasflowed cylinder head £450
KTR performance camshafts £549/pr
KTR alloy crank & alternator pulleys £tbc
KTR lightweight flywheel £249
KTR group N clutch kit £325
KTR/Samco white silicone water hose kit £198
KTR alloy header tank £129
KTR/Iridium Power spark plugs £45
Magnecor 8mm ignition leads £58
Race battery £98
KTR carbon oil catch tank £69
KTR stainless steel front strut brace £99
KTR alloy front suspension top mounts £135
KTR/Gaz Tracksport fully adjustable coilover suspension kit £749
KTR camber bolts £35
KTR rear camber shims £20
KTR alloy roll cage (powder coated white) £295
KTR spec 300mm 4 pot grooved front brake kit £675
KTR Tracksport grooved rear brake discs £159
KTR stainless steel brake lines £55
Carbon Lorraine front & rear brake pads £89 & £48
Ultralite 17" x 7" Redline lightweight alloy wheels £99 each
TOYO 195/40 R17 T1-R tyres £65 each
Clio Trophy rear spoiler £165
KTR carbon bonnet £330
KTR carbon front splitter (matt finish) £95
KTR front brake duct kit £tbc
KTR carbon fibre reclining sport seats £299 each
Raid suede steering wheel £119
Sadev sequential gearlever
Sadev gear indicator
Sadev full throttle & clutchless gear shift kit
White dial conversion kit £29
Full alcantara trimmed dash and door cards £500
KTR floor mats £75
KTR graphic set
The engine is yet to be fully mapped but this should be done in the next couple of weeks.
David.
M
mini-valver
LOL! Indeed!
Shorter trumpets will make less torque, but when you have an airbox on them anyway, it'll make less of a difference and it looks a hell of a lot tidier. Whats 5 bhp on a road car? Juts make it up in the bends with you HUGE testicles.
  b/g 182, meg tourer
LOL! Indeed!
true. lol
Christopher
  Z4M
LOL! Indeed!
LOL
Knowsit.
Nice avatar too. :cool:
Owen
ClioSport Admin
Nice one for the link guppy, was clio_il trying to say that the k-tec ones will be making less power than the gdi (which given they were cheaper, i would expect anyway!)
  ITB'd 182...
not to sure tbh. with either kit your not getting cams with the packages but are worthwhile mod if you do TB it imo. think they're both very simular just depends on which garage (gdi up north-k-tec down south) is closer.
also you see alot more cars with the gdi kit than the k-tec but am unsure weather this is due to the fact that gdi have been doing TB kits for longer? am sure someone with more knowledge on the facts will be along to get the facts straight for you matey:)
M
mini-valver
Exactly.
The coil pack bracket could be better, but it looks neat and tidy which is the main thing. Its for a road car FMP, not a track car so looks are just as important.
I realise you have that bracket though ;)
  Mk2 172
They look sh*t hot to me and look like there supposed to be there. No panels cut about and no stupid cable ties everywhere as if someone at uni had done it in there lunch hour. Like the idea of keeping the aircon too. 210 bhp ish sounds good too :)
  ITB'd 182...
k-tec claim that you can drive in and out in a day and have bodies fitted. would that include the omex set up or you think you would have to retun or go to have them set up elsewhere? as they say a quick map to get you up and running?
M
mini-valver
They'll put a base map on it but you want it live mapped after really.....
  ITB'd 182...
thats good. have cams fitted at same time so your cam belt will be changed, another plus point, but with fitting and labour and live mapping and bits and pieces maybe i would be better off with the gdi kit price wise?
