This is a known issue, as the stealth is a bit too heavy for, as mentioned, cheese (more likely a soft cheese like brie :rasp mounts.......
I sorted mine by loosening the clamp between rear and mid section, and loosen the rear box strap (that the rear hanger is attached) and rotate/twist the rear section, looking from the back to the front of the car, in a clockwise direction. Then once you are happy with it, and it is hidden enough, tighten the clamp and strap up again.
The rear box should now be 'higher' under the bumper.......
Many people also go for the cable tie fix instead, which involves putting cable ties through the holes to hoist up the centre pin...........this can also be improved with some tubular metal inserts, much like those that are pressed into bushes. Basically you are looking to bulk up the holes within the rubber hangar so the centre pin is held higher........cable ties are needed for this too!
The rear mount design reallt is crap. I put a new one on 4 months ago and already the rubber "X" crosssection is noticeably sagging and thats just the weight of a standard backbox. I also changed the middle mount to make sure the weight of the middle section was supported properly there. Think when it goes Ill just make up my own mount.
