Keeps revving?
Car  CLIO 172 EXCLUSIVE
Ok if im in traffic the car keeps revving up to about 2k, if i flick the accelerator up it drops back down to normal, any ideas?
Throttle cable realy needs chnaging but try lubbing it up a bit.
The real isue is the fact with age the spring looses its streght and the cable gets stiff.
New cables arn't much not a huge job to chnage.
I have the same problem, already changed the throttle cable, cleaned the throttle but still no change :/ any other ideas ??
I dont think thats it ! there is no tension on a throttle cable when the pedal is relised.
Update... now ( after cleaning throttle) the rpm rounds abour 1500 not 2000 like it did before :/ but the problem still remains :/
i would suggest making sure the black bracket that the throttle cable attaches to on the back of the throttle body is secure,mine used to stick at these revs,but once i fiddled with that mine has been fine
I have a fix for this, I went through 3 cables and two throttle bodies and it still did it.
It's a Renault Design fault, due to the original cable coming from the left side of the car and being shorter, when they made the UK spec they put a longer cable on and that's the problem.
I have sprung my pedal, piece of piss to do. The pedal becomes harder to push but comes straight back up under your foot and it doesn't stick.
this worked 4 me !!!
Riddzz, any chance of putting a photo showing where you fixed the spring on the pedal?
Cheers, Rob669
