Key fob battery?
Car  Mk4 .:R32
My remote central locking doesn't work, assumed it's the battery.
Where can you get a new battery from? Are they just like watch batteries?
How easy are these batterys to fit ?
Is it just a case of taking key apart and out with old and in with new battery ?
Or do they need programmed again after new battery is inserted ?
^^^ They just slide apart .Well i say " just " slide apart . You have to apply a fair bit of pressure tbh . Old battery out , new battery in job done :)
What range do your key fobs work in? I have to use mine close to the Clio?
Is this a sign the battery is on it's way out?
Mine works from up to about 8 metres away at the moment, which is less than it used to. I just tried with the spare key (hardly ever used) and it worked from about 15...
Edit: I'd guess if yours are working from a ridiculously short range it must be the battery, unless there's an inherant fault in the key. A new battery will generally increase the range regardless but the extent depends on whether the key itself is defective of course! :)
