Mine works from up to about 8 metres away at the moment, which is less than it used to. I just tried with the spare key (hardly ever used) and it worked from about 15...
Edit: I'd guess if yours are working from a ridiculously short range it must be the battery, unless there's an inherant fault in the key. A new battery will generally increase the range regardless but the extent depends on whether the key itself is defective of course!
