Key fob
Car  Clio RSI 1.6
Hoping this is the correct forum, if not can it please be moved - cheers!
Okay, the other day I started to load up my boot, locked it and went to get more stuff as I always do, came back, key fob wouldn't do anything at all, barely lighting up as I pressed it. Got someone to drop off my spare key, it was fine, opened/locked first time no problem.
So, figured it was the battery in the fob that'd died, so went and got myself a replacement battery, put it in - sweet, lighting up etc again. Went to try it on the car, nothing! The other key fob worked fine, but the old one that'd have a new battery in still wasn't working. Asked a mate and he reckons it's reset itself and needs to be reprogrammed to my car again.
So question is, how do I reprogram my key fob? I have literally no clue where to start, but eager to learn! lol
Thanks guys!
stick it in the ignition
turn two clicks (one before it starts)
press the button
should do it, works on other cars i've had
it's usually only the immobiliser that needs reprogramming by renault, not the central locking
just click usually. the battery holder in the vauxhall keyfobs keep coming apart from the circuit board and you have to reset using method above
