Knock knock knocking!!!???
Car  PB 172 phase 2
Drove back home and everything seemed fine with the motor. I got indoors forgot something and immediately went back out again in motor, only a knocking sound has somehow developed in the short while that it was turned off? The knocking increases with speed or clutch engaged? It's pitch black out at the moment so no point checking? Any ideas? Back box mount seemed fine?
Thanks for replying. I just started it and revved it in neutral and no knocking but if I revved the ass out of it there was an almost knock? I moved the back box up n down and it kinda sounded like the same knocking? But the hangars all look fine?
check your engine mounts for excessive play, sounds like your exhaust, the engine wont move around much when jus revving at a stand still but put some load on it and itll dance around, when my driver side engine mount sheared my exhaust rattled to hell... check d/s engine mount, gear box engine mount and the dog bone, your exhaust mount could be fine but if your engine is swinging about the exhaust can easily hit on things...
