Knock on Full lock ?
Car  172 Ph2, Mk1 MX5 1.8
If I'm maneuvering and hit full lock I occasionally get a knock/creak from the drivers side front somewhere.
Car is a PH2 172.
Any Ideas ?
Si
anti roll bar linkages? especially if your car has been lowered. Mine were shagged after about 2 days of lowering it. replaced them and its been fine ever since!
I'm having the same issues on my 182FF.
How much would I be looking at to get it sorted?
PS does it make a massive amount of difference if I just leave it ;)
Car is completely standard, only get the creak when I'm reversing or pulling off on full lock, Top mounts sounds feasable, I'll try the washer fix first.
Ta
Really ?
What has to be ground away, the strut tops themselves ?
Bit reluctant to start grinding away at the body work, I may try the washers first, if that doesnt work then I'll look at the grinder :p
Cheers Danny
Interesting, so the washers may actually make things worse !
I might just leave it then to be honest it only knocks very occasionally when on lock, presumebly wont cause any harm left ?
