Knocking noise when turning right. Driveshaft?
Car  FF Titanium 182
I've noticed a knocking noise coming from the car when I turn, only seems to be when I turn right. I'm having a guess at saying it's the drive shaft would it be the drivers side that needs replacing? Cheers
Is it knocking with every rotation of the wheel? Or a knock when you first turn and when your hitting bumps etc?
mines knocks when i turn left. or go over a hump . i noticed that the gator on my driveshafts isnt on properly . its come off so probably your and my cv joints lol check your gators still on properly and greased up .. and check your balljoints also.. im from bham too
No just knocks when it is turning right, gets quicker the faster it moves, im pretty sure its a shaft from the noise
Have you had drive shaft out at all because it might be the big nut loose I know it don't happen but my old mk1 golf had that and turned out the bolt was just loose tightens it and went
