Knocking when first setting off...
  Mk4 .:R32
For some reason, when I first start my car up and set off, it makes a 'clunk' noise.
Any ideas?
  Mk4 .:R32
well the gear is already engaged.
Say I'm sat in my car, I start it up, select first, take the handbrake off and just as I start moving it makes a big clunk noise!
ForceIndia
  Gentlemans spec 200
I'd bet a bic mac and fries on it being the rear pads sticking, don't move when you take the handbrake off, then suddenly lets go when you move. Do you have a garage? Stick it in overnight, no handbrake just leave it in gear, if no noise the next day, sorted!
  182
^Ah yes after re reading its probably that, mine does the same sometimes. You can normally tell as it holds the car back slightly till it releases.
