Ktec stealth... loud to quiet - how?
  Titanium ph1 turbo
So I'm maybe buying a ph1 with a Ktec stealth.. but it's the loud version... how do I make it quiet, is it just the centre section I would need to worry about (as in change)?....
Also if the car has a 182 manifold (on a 172 ph1), does this mean it's likely to have the ph2 ktec stealth fitted, assuming they have either a ph2 decat pipe or ph2 cat hanging off the 182 manifold?
Thanks in advance
I put a sport (silenced) centre section on mine. Still loud over about 4k rpm but a bit more social able at low speeds. Kept the wife happy as she said it was too loud before... Would say its more likely you have a phase 2 system running off a 182 manifold. Probably changed so the ktec system could be fitted.
  LY 220 Trophy+IB PH1
As above I've got the 2.5" silenced system and it's by no means quiet, it's boomy to some degree (People sat in the back struggle to have a convo) Always wondered if a 2.25" straight through section would sound better.
