L.E.D Interior Light Bulbs?
Car  PH2 172
Iv been wanting to change my interior light bulb to a L.E.D white bulb but not sure on where to get 1 from any ideas peeps and anyone got any picstures with theres done.
Gimme a sec and il Tell you. You can buy them from www.shinyautos.com
BUT from what I remember a cups set-up is different from a normal 1*2 for the interior light (where the map light is etc)... Il be back...
Right found what I was looking for about the interior map light etc..
right fitted mine about 10 mins ago and a bit pissed about 2 things:
1. the main interior light only work either when opening the door or by reversing it you can use it as the interior light for reading maps etc - not both!! this is fecking annoying.
any ideas anyone?
I've had the same problem on my Cup, done a bit of investigating and this is what I found.
The light uses a centre positive connection, a permanent ground on one side and a switched ground on the other side. When you switch the light into different positions it reverses the polarity onto the bulb. This is no problem with the standard bulb as it will work with current flowing through it in either direction and therefore will work in both positions. However, with the LEDs it means that the light will only work either:
1. When the light switch is in the position where it is activated when the door is opened, and will not work when you try to put it in the position where it is permanently
2. When the light is in the position where it is permanently on, but will not work when the door is opened.
To rectify this you can put a second bulb in parallel with the first bulb, but with its polarity reversed. If this is done, then the light will work in both positions (one bulb for each position). Unfortunately there's no easy way of mounting a second bulb, and at the moment it looks like it will probably be wires soldered to the bulb and to the contacts in the light to make this work.
This should be all the information about what bulb types they are too :)
I might try that site too, can all the bulbs be got and is the price much different?
You can get them yes, although they only come in Amber or White. And the Festoon type (For the glove box) is £4.99 each! s**t a brick!
FESTOON TYPE http://www.ultraleds.co.uk/advanced_search_result.php?keywords=festoon&x=0&y=0
Interior Lights and sidelights are on this page
http://www.ultraleds.co.uk/automotive-bulbs-501194t10w5w-10mm-wedge-c-101_129.html
ALSO FOUND THESE
http://www.ultraleds.co.uk/uf12ww-ultra-bright-wide-angle-501ba9269264239-p-1331.html
So for the interior light once fitted the L.E.D i can have it so when i open the doors it comes on and when i lock it, It goes out and can i have it so when im in the car and i put the light on it come son so i can see what im doin at night all i want is the glove box interior light and boot light can i not get them from ebay fr much much cheaper?
Do any of these fit a normal 1.2 dynamique?
Should do. They are all the same fitment. Once I have posted up the measurements of mine etc tthen if you compare your sizes to mine...If they are the same 'Jobs a Good un' :)
Okay this is what mine are...
First the Glove box and Rear Boot one is this..
Its a "festoon" type and these should cover it
http://cgi.ebay.co.uk/2x-XENON-WHIT...hash=item180268945114&_trksid=p3286.m14.l1318
And this is the Map/Interior Light one.
Its a 501 type LED and I reckon these should cover it
http://cgi.ebay.co.uk/2X4-LED-Xenon...hash=item180266428957&_trksid=p3286.m14.l1318
I could try and find cheaper ones but thats the easiest.
Or you could just buy the whole set from here....
http://shinyautos.com/shop/product_info.php?cPath=25&products_id=249
Pics of my Blue ones which Im changing to white soon
yeha look good think they would look better in the xenon white which i want il check my messurments later today
Can someone whack up some pics of the white ones at night when they arrive. I want to get some soon, the blue look nice, but am interested to see the white
I wonder would these fit??
http://cgi.ebay.co.uk/Car-24-LED-In...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
